Tps question help!!!!
Old Nov 3, 2004 | 11:42 AM
iloveslayer's Avatar
Car: 89 iroc 350
Engine: 350 tpi
in the tech articles for iac and tps it says " disconnect the connector from the TPS. Using your jumper wires, make a connection allowing some room for the VOM terminals to contact the jumper leads and read the TPS voltage. " but it does not say which of the three terminals to connect to to test the voltage. also I am assuming this means to put the jumpers inside the female end of the tps connector and test from 2 of the termainals. The article isn't exactly crystal clear and there are no diagrams.
Old Nov 5, 2004 | 12:18 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Tps question help!!!!
Here you go...http://www.iroczone.com/techarttpsadj.html
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
