Down side to putting gears in?
I hope you like being broke because your car sure will like the gas!
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
The downside is you'll lose a little bit in top-end speed. But then, people don't put 3.73's on cars for the top end speed.
You'll notice an improvement in low-end power.
Your car probably will eat gas like crazy, but it's more due to the current tranny and carb. Just putting a 3.73 on, however, makes little difference.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
89 iroc-z 305 tbi
dhonda200
Aug 11, 2015 11:50 PM
novaderrik
Aug 10, 2015 12:44 PM
