Low Power
Old Nov 3, 2004 | 01:49 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
Low Power
Ok guys, this POS Talon Turbo wanted to race, so i gave it to him, and after i won, my power stearing went dead and my heat went way up and my battery level went way down. What is it?
Old Nov 3, 2004 | 01:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Belt.
Old Nov 3, 2004 | 01:54 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
what belt
Old Nov 3, 2004 | 01:55 PM
five7kid's Avatar
The power steering/water pump/alternator belt.
Old Nov 3, 2004 | 02:03 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
as in they all got blown off or i need new ones?
Old Nov 3, 2004 | 02:32 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
why don't you open your hood and look. if you have an early model car you will have V belts. If you have a later model you will have one serpentine belt.
Old Nov 3, 2004 | 02:34 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
i know i have a serpentine belt, the car still runs just fine, just that the heat shot up and battery power went down and so did the power steering.
Engine: 5.7, 5.0
did you look to see if the serpentine belt is still there?
Old Nov 3, 2004 | 02:42 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Quit stalling a look! Also whens the last time you changed or even looked at your oil?
Old Nov 3, 2004 | 02:43 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Ok for one, the car is at school, and for two, the oil was chagned about 2 weeks ago. thank you. I will find out within the hour about the belt
Old Nov 3, 2004 | 02:51 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Good, i just wanted to make sure you weren't one of those guys that puts 50,000 miles between oil changes.
Old Nov 3, 2004 | 03:41 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Like me!! I'm getting close to 4,000 I think... Mobil DriveClean 10W-30 and a AC Delco PF454S filter though and the oil looks good. I just have to get around to changing it (gonna have plenty of time this weekend).
Anyways, back to the topic, I guarantee its a belt as mentioned above. Does your AC work (if you have AC)? Can you even start your car anymore (without the belt, the alternator can't charge the battery)? What year is the car that would determine V-belts or serpentine.
This reminds me, I need a new belt as well. Trying to hold off until after I pass emissions so I can get a shorter belt to remove the AIR pump..
theshackle
Sep 17, 2020 08:26 AM
soarestransam
Sep 1, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
novaderrik
Aug 10, 2015 12:44 PM
