Strange problem
Old Nov 3, 2004 | 05:23 PM
FBird84's Avatar
Strange problem
My water pump had died and was leaking so i change it, now my Tach is jump around wildly and there a strange noise coming from under the hood. The noice started when the WP had started leaking fluids shouldn't it have stop now?? What else could make a tach jump around wildly?
Old Nov 3, 2004 | 05:29 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What car is this for, what engine, what induction, tranny.... Can't really tell you much if we don't know what you have.
Also please re-explain your first post, i makes no sense, i got water pump leak and tach flutuating.
Old Nov 3, 2004 | 05:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You probably have a loose plug wire.
Old Nov 3, 2004 | 06:00 PM
FBird84's Avatar
84 firebird 305 v8. My tach was flutuating and there was a strange sound coming from under the hood. I check everything out and found out my water pump was leaking. So i chalk it all up to the Water pump going bad. Now i just got the water pump fixed and there's still this strange noise and tach it still flutuating. What else would make this happen?
Old Nov 3, 2004 | 06:38 PM
Air_Adam's Avatar
Check your plug wires, thats exactly what happened to me when one came loose. The tach needle bounced around and the engine ran and sounded funny (duh, lol)
Old Nov 3, 2004 | 08:08 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What car is this?
Old Nov 4, 2004 | 07:34 PM
84camz28's Avatar
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
distributor maybe
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
andy74
Sep 3, 2015 08:41 AM
IROCtometal
Sep 2, 2015 02:01 PM
