Okay so I've studied the custom belt diagrams..
Old Nov 4, 2004 | 12:43 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I want to figure out a belt routing that removes my AIR and A/C pumps. Okay, so I have a picture of Adrenaline's "Super Duper Snazzy" belt routing.
Good! Great! I just want to move my alternator..
Is it possible to relocate my alternator to where my AIR pump is? I haven't looked at any of the bolt spacing at all so I have no clue. I was curious if anyone has done this. I'm trying to free some room in front of the heads so I can figure out the coolant hoses for the LT1 heads. Otherwise, I'll just put them in the back, but I figured if I could put them in the front and re-route my accessories, all would be good. I need to buy a new serpentine belt soon enough anyways..
Old Nov 5, 2004 | 08:46 AM
wtrskiscout's Avatar
I also have studied the diagrams and I am trying to decide the cleanest and easiest way to run belts.
Here's my question?
Can the LT1 serpentine belt setup be bolted onto a "regular" small block?
The LT1 doesn't have a belt driven air pump and even though it has an electric water pump, it looks like the belt could be used to run one if installed.
I hope this isn't highjacking your thread.
Old Nov 5, 2004 | 10:50 AM
Car: 1997 Corvette
No that's fine. I don't think it will work though. The 4th gens use R&P steering so the p/s pump probably wouldn't work. What would be the advantage? I also didn't realize the LT1 had electric water pumps...are you sure about that?
MrPackstin
Oct 25, 2017 08:09 PM
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
