Eagle Main Caps
Old Nov 4, 2004 | 03:04 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Eagle Main Caps
Hi
87 2 bolt Hyd Roller block and getting ready to set up
machining for 383 setup.
Thinking about going to 4-bolt set up.
Reputable online store has the three center splayed
caps for $80.00. They are the Eagle brand.
Seems kinda cheap to me.
Any one have any experience or advise on them
Later
jaykar
Old Nov 4, 2004 | 05:06 PM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
Never used them before but you will need to get the mains rebored. This will mover the crank center line higher in the block. Problem with that is with the 400 stroke you might have to get a small base cam and stock timing chains will be lose on it. How much power are you planing to make the you need a 4 bolt?
Old Nov 4, 2004 | 05:10 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
when they rebore the mains they only take about hafe a thousands from the block, not enough to be worried about
Old Nov 5, 2004 | 11:41 AM
jaykar's Avatar
Main Caps
Hi,
Thanks for replys.
Was just wondering about the brand name.
Know they also make the cranks and rods for the
strokers.
Was going to just stud the 2-bolt but would still
have to line bore with them also.
As to line boring and slack chain and cam clearance
finding the best machine shop will take care of that.
Cam lift .550-.575 and 230-235@50 shouldn't be a
problem.
HP est- 480-510 with Miniram & good head-195cc.
Any more input on these caps appreciated.
Later
jaykar
Old Nov 6, 2004 | 05:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I've always been under the impression that thye fasteners used are more important than the caps they hold...i/e my "guess", unless some infrior casting process is used by Eagle) is that if you used the caps with ARP hardware, you would be okay....could Eagle be any less inferior than stock GM two-bolt caps that are splayed?
Old Nov 7, 2004 | 01:42 PM
jaykar's Avatar
Hi,
As to less inferior,
I don't know about Eagle, but some of the cranks rods ect
that are being sold over here come out of China.
And Metalurgic quality supposedly not on par with ours.
But can't always believe everything you read.
Have read quite a few posts on this subject.
Later
jaykar
Old Nov 7, 2004 | 08:30 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
eagle stuff is straight outta china
Stryker412
Sep 20, 2015 06:59 PM
F-body-fan
Sep 17, 2015 12:16 PM
gta892000
Sep 16, 2015 12:37 AM
Nick McCardle
Sep 10, 2015 08:36 PM
