305 with 350 heads
Old Nov 4, 2004 | 03:32 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
305 with 350 heads
I have heard that 350 heads will not fit onto a 305 without getting the cylinder bores punched out, on account of valve interference with the cylinder walls. Is this true?
Old Nov 4, 2004 | 03:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Considering as how plenty of factory 350 castings are 1.94/1.5" valves, they (valve sizing) will fit.
Whether or not it's smart to put 350 heads on a 305 is a whole new matter.
Old Nov 4, 2004 | 03:40 PM
Zed'er's Avatar
Car: 84 Z28HO
I have a pair of heads from a 327 that have 2.02' Intakes. I suppose they wouldn't fit.
Old Nov 4, 2004 | 04:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In most cases, there isn't a problem.
But, you should limit valve lift anyway. The biggest issues are valve shrouding by the cylinder wall, and chambers too large for proper compression ratio.
Old Nov 23, 2004 | 12:29 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Bump so as not to start my own thread.
I'm going to be putting 350 heads on my 305. I'm assuming I should get head gaskets for a 350? Is there going to be a detonation problem at all withe the 1/8" ((4-3.75) / 2) mistmatch all around the circumference of the cyls?
Old Nov 23, 2004 | 10:40 AM
ljnowell's Avatar
Are you kiddin me? With that whopping 7:1 compression ratio you are going to make, there wont be any problems with detonation!
Old Nov 23, 2004 | 01:35 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Most of the gaskets are the same. For some odd reason a few of them are listed 327/350 only. Havent figured that one out yet, I guess I better go look for water in the oil of all the 305's Ive used 350 gaskets on.
I guess If you were to use 64ishcc heads and flat tops the compression wouldent be too low on a 305, sure would idle smooth with 7:1 compression.
Old Nov 23, 2004 | 01:45 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Hey, it'll run on the cheap stuff! lol!
Old Nov 23, 2004 | 01:47 PM
Car: 1997 Corvette
305 LB9 heads = 58cc combustion chambers
Aluminum LT1 heads = 54cc combustion chambers
My compression will go up...hopefully to 9.8+
Old Nov 23, 2004 | 02:59 PM
ljnowell's Avatar
Thats the truth!
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
