oil pump pressure spring replacement ?
Old Nov 5, 2004 | 05:55 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
just an "oh, by-the -way" question here - when replacing the pressure spring in the oil pump, i noticed that the pump's original spring was "spread" at the end where the pin goes through to retain it, and was wondering if anyone does that same thing when installing a new one, or just leaves the replacement spring "as is". i don't see any way it could possibly come out, but just wondered if anyone else does that...
KAM
Old Nov 5, 2004 | 06:50 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I've always just installed the spring as-is. First motor I used the high volume pump and installed the high pressure spring. Carried 60-75psi at start up and 50 at an idle.
This motor I just ran the spring that came in the pump and discarded the high pressure spring. 75psi at start up and 30 psi when hot. Carries plenty of pressure as soon as rpms come up.
Old Nov 5, 2004 | 08:08 AM
ede's Avatar
ede
always as is, i figure they're smarter than i am so i don't try to out think them ( the spring maker)
Old Nov 5, 2004 | 09:23 PM
Car: '91 Z28
Axle/Gears: 323's
i left mine as is, too. was just wondering cuz inquiring minds wanna know. when i see something different, i like to ask cuz you never know when someone has a better way of doing something... my oil system's already buttoned up and filled with oil anyways, i really don't know what made me even think about it...
KAM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
