wats the deal with colder plugs for no2
Old Nov 6, 2004 | 12:57 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys ive read that when u use nitrous that u have to get colder plugs,is this true?if so were do u get them at? and how will i know which ones to get?
Old Nov 7, 2004 | 11:40 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Yes depending on what HP shot of nitorus your running you will need colder plugs and retared your timing a couple degrees. Just get the number off your factory plugs and go to the parts store and tell them you need a plug that is 1-2-3 steps colder that the facotry plug,again depending on the shot your running.
Old Nov 7, 2004 | 06:55 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
i'll be using a 75-100 shot. The people that work in the auto parts are dumb so they wont know what that is.
Old Nov 8, 2004 | 01:18 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
If you use a t43 plug, go to a t42....simple as that.
Old Nov 8, 2004 | 05:53 AM
EvilCartman's Avatar
Car: '82 Z28
You wont need a colder plug with a 75-100 shot.
Old Nov 8, 2004 | 08:08 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
so im okay with the stock ac delco plugs.wat about timing leave it alone or lower it?
Old Nov 8, 2004 | 08:17 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
keep your timing where it should be stock if you're using the stock ecm. if you havn't messed with your timing before, leave it alone and you should be fine.
Old Nov 8, 2004 | 09:07 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I have found that autoparts stores don't know didly besides what the computer tells them. I tried to get a step colder for the 355 than the "recommended" b/c it was running bad, went in and they kept asking for the car year etc, even though I don't need the stock plugs w/ the TFS heads... Glad I know the PN now so I just ask for that instead of messing w/ some non-knowing punk...
Old Nov 8, 2004 | 09:15 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
okay .i think autoparts should actually hire people who know there ****
Old Nov 8, 2004 | 10:13 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Thats gonna be super hard to do for the most part. Don't get me wrong, there are places w/ very knowledgable guys. I don't mind the stupidity, or lack of knowledge as much as I can't stand it when they keep asking for the car specs, when I have told them it doesn't matter, and I need to crossreferecne a part!!!
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Aug 28, 2015 05:57 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 27, 2015 07:28 AM
Hello, Michael
Aug 20, 2015 03:19 PM
