Gas tank removal
Old Nov 6, 2004 | 05:08 PM
ffvetteman's Avatar
Gas tank removal
To remove the gas tank in a 89 RS Camaro, do I need to remove any of the rear suspension. I looked at it shortly before work and thought I may need to. I need the hole tank out of the car.
Old Nov 6, 2004 | 05:13 PM
ede's Avatar
ede
you need to lower the rear as much as you can, plus raise the car as high as you can. the exhaust most likely will need to be removed too. it's a big help to have a extra set of hands helping and to drain the tank. it sounds a lot worse than it really is to do.
Old Nov 6, 2004 | 05:16 PM
ffvetteman's Avatar
OK. The exhaust is already gone(car being parted out) and I have it raised in the rear with the jackstands under the rear carrier. So just lowering the rear suspension should give ma enough clearance?
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
