383 stroker advice needed
Old Nov 7, 2004 | 06:46 AM
paul5.0's Avatar
Car: trans am 1991
Hey guys, Im building a 383 out of a roller 1997-1995 350. Would it be harder to do with the roller block? is the cam the only thing that is rolling? what exactly is the difference between the rollor motor and the traditional block? Will it be harder to build? I heard hi revs are bad for the rollor motors when stroked out. Whats the highest powerband i can get out of this motor?
Old Nov 7, 2004 | 07:45 AM
ede's Avatar
ede
roller cam, or block wouldn't make much if any differance. you might want to look at small base circle cams. cranks for one piece seals might be something to consider too. i'd look at what parts i could get for the block and price before i commit to a block.
Old Nov 7, 2004 | 11:43 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The only difference is that the lifter bores are alittle taller, and there are cast bosses for the lifter hold "spider"
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
