6 to v-8 swap ? accessories
Old Nov 7, 2004 | 12:00 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
With new brackets can i reuse my 87 surp accessories on a 71 350 block with the accessorie mounting holes in the heads? I was wanting to go junkyarding and get the brackets, crank pully, and tensioner so that i could reuse all of my good condition acceries that are on my V-6.
i didnt know if there was anything different in the mounting of the A/C, PWSteering, and the alternaters should all be the same in mounting right?
Also i dont know the difference between a short water pump and a long, and what applications used what.
Thanks in advance
Old Nov 7, 2004 | 12:19 PM
ljnowell's Avatar
You will need all the bracketry from a V8 engine with serpantine setup. The pulley will have to be taken off the V6 Power steering pump, and the bracket switched. Everything else should work though.
Old Nov 7, 2004 | 01:20 PM
Car: 87 Firebird
Engine: 5.3 76mm
Do the Surp equiped V-8s use a short or long water pump, thats in reference to how long the legs of the pump are right?
Old Nov 7, 2004 | 01:40 PM
ljnowell's Avatar
AFAIK, All SBC for a long time have used the long water pump. All the serpentine and v belt cars I have owned have had the long water pump on it.
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
formula_novice
Sep 5, 2015 03:58 AM
neekolzun
Aug 24, 2015 04:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
