Brake line help requested
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I need to replace my hard lines (the ones that run from the front of the car to the TBI- the feed and return lines) with flexible hoses so I can tighten my TV cable (Vortec heads with that crappy mounting bracket which runs into the lines). Anyone have part numbers for pre-cut lines or any suggestions? I noticed a small dent on my hard feed line which may be hurting my performance. Plus, I have been meaning to replace them anyway.
Thanks a lot guys
Thanks a lot guys
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
brake lines to the tbi?
do you mean gas line?
this post confuses me, maybe thats is why only one responce.
www.finelines.com
connection for all kinds of formed lines, brake gas power steering , transmission lines too.
jeff
www.finelines.com
jeff
Car: 1992 Firebird
Engine: forged 357
www.finelines.com
jeff
www.finelines.com
jeff
can someone edit that real quick?
