starter woes
Old Nov 8, 2004 | 01:44 AM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
starter woes
i finally got my damn starter off and out, but now i have the next problem..
getting it back in there and aligning the bolts, there is only one way i can get the starter up in there and then i have to turn it, but the solenoid hits the oil pan and i cant turn it any furter, ive tried at it for a good 2 hours and havent had any success, any ideas?
oh yeah, the starter came with some shims, 3 to be exact, should i use them? or should i just not worry about them
Old Nov 8, 2004 | 01:45 AM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
im really contimplating on cutting off the exhaust under the starter and just waiting to get it welded back on, noise isnt a problem considering i love the loud engine sound, but also, that my last resort, so please, any ideas?
Old Nov 8, 2004 | 09:30 AM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
If the starter came out with the right combo of twisting and maneuvering, it will go back in........however, short of that, 2 hours can be a killer on the arms!
Another option is to take the selenoid off, put the starter up into approximate position, after getting everything past the pipe, and re-attach selenoid just before you push it all the way up into position.
No need to get drastic and start cutting things. Good Luck!
Old Nov 8, 2004 | 04:58 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
if i take the solenoid off, what is involved?
i know there are 2 bolts, and there is a metal stopper thing that i have to take off, is that it?
im at my girlfriends house right now and we are about to go and cut the exhaust around the area of the starter, im not really worried about the loudness, but if i do cut it off, would a muffler shop be able to weld it back on? i dont want to cut it if that means i have to buy a new y-pipe. please help, thanks.
Old Nov 8, 2004 | 06:18 PM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Yes, that is all that is involved with the selenoid. Not the preferred or recommended method, but if you feel the need to cut your exhaust pipe, go right ahead, a muffler shop can reweld it.
Old Nov 8, 2004 | 09:00 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
i cut it, only once, made it so i could move the exhaust enough to turn the starter, bolted it all up... didnt start
i checked the fuel pressure, this time i got no squirt, so im stuck with a bad fuel pump! yay....
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
