Charging the AC system
Old May 30, 2001 | 07:40 AM
El Guapo's Avatar
What all is needed to do your own charging of a R134a system?
Clayton
Old May 30, 2001 | 08:15 AM
irocbsa's Avatar
A recharging hose for the low pressure port, cans of r134 refrig., and a can of r134 compressor oil (NOT PAG oil). You can get all this in a kit at most generic auto parts stores. They sell retrofit kits if you need to change from R12. I got mine for $35. A 12 oz can typically goes for about $7.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
Slush92RS
Sep 2, 2015 08:56 PM
