Distributor Issues
Old Nov 8, 2004 | 03:13 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Distributor Issues
My engine (305) is so hard to turn over it sounds like the battery is dead, which it isn't. My question is, if the distributor is out by a cog, or even possibly bent, would it make for a hard turning engine?
It turns over very slowly, then after about 5 to 10 seconds, it will fire up. I am getting so fed up with it. An after thought, on a quadrajet carb, which direction of the air/fuel screws (don't know what they are called) makes it richer or leaner? Is it in for lean?
Old Nov 8, 2004 | 04:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like you could need a new battery, battery cables and/or starter.
Old Nov 8, 2004 | 04:16 PM
Zed'er's Avatar
Car: 84 Z28HO
Brand new battery and I tried switching cables, and the starter worked fine on the engine stand.
Frozer!!!
Jan 19, 2024 04:55 PM
777Shock777
Oct 29, 2015 04:30 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
