Oil Change Info needed
Old Nov 9, 2004 | 03:48 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Transmission: Auto w/ TransGo shift kit
Hey all.
Last Sunday I changed the oil in my car, unfortunately I don’t have the owner’s manual so it’s kind of difficult to get specific info.
Can anyone tell me how much oil I should put in? One of the books I have says 4 quarts without the filter, that’s all I could find out.
The oil is a little over the full mark now but I am not sure how much I should put in.
I changed the filter too, filled it up ¾ with oil (around 200ml / 6.75 ounces) and then a little over 4 liters (~4.2 quarts) in the motor.
The car is a Camaro RS 91 305 TBI Auto with AC (no major mods).
Is this the right way to do it, does 4.200 liters (4.4 quarts) with a filter change sound right ?
Thanks.
D.
Old Nov 9, 2004 | 03:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They say 4.5 quarts if you put on a dry filter. I put on a full filter and add roughly 4.2 or so quarts after that. You shoul dbe fine. Your dipstick will tell you when you are in the "okay" range. Just don't over or underfill.
Old Nov 9, 2004 | 04:51 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Thanks Shifty.
I thought 4.2 quarts with a wet filter would be about right but I wanted to be sure.
Thanks again.
D.
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
