What is valve lash?
Old May 28, 2001 | 01:24 AM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
What is valve lash?
Can someone explain this to me, please?
Old May 28, 2001 | 05:57 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm sure someone can explain it better than me, but I get it started.
It refers to how tight you make the rocker arm to the pushrods. You have to tighten them to the correct valve lash or you could bend or break your rods.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
Soon to be installed B&M Megashifter
and Exhaust Cut-Out
Old May 28, 2001 | 11:05 AM
ede's Avatar
ede
valve lash is the clearance between the rocker and the valve. on mechanical lifters you have clearance you set with a feeler gage on hydrolics you tighten the rocker until you have contect between the rocker and valce and then tighten another 1/2 to 3/4 turn (on SBC). some engines don't have an adjustment and others use a differant method to set clearance.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 30, 2001 | 08:47 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Thanks guys!
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
