can i use this water pump?
Old May 31, 2001 | 07:23 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
a buddy gave me a chrome water pump for this 350 tpi that i'm puttting together.it's your standard long style small block chevy water pump.the motor i'm putting together is a 1989 5.7 TPI.as long as it's the right style(long or short)it'll work right?GM didn't have reverse cooling untill 93 right?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old May 31, 2001 | 08:02 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I think they had reverse cooling as early as 86? I beleive it was when the cars went to the serpentine setup. This pump will not work on your car.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old May 31, 2001 | 09:48 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
If he was using a serpintine system and that's what you plan on using it should be ok I think. Do you know if it's reverse flow or not?
Old May 31, 2001 | 10:39 AM
91banditt2's Avatar
Engine: 5.7 HSR
thanks guys
anyone know for sure?
it does have a threaded hole for a altinater(spelling)bracket
Old May 31, 2001 | 10:50 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You have to find out if it is a reverse rotation pump or not. The WP spins counter clockwise on serpentine belt cars, clockwise on regular V belt cars.
The only reverse flow cooled chevy engines are the LT1/LT4/L99 engines. Reverse flow has NOTHING to do with the rotation of the WP.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
83 Crossfire TA
Jan 3, 2016 01:26 PM
86iroczwv
Sep 3, 2015 06:21 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
