Got the headers on....now how do I put the dip stick tube back on????
I just put a set of the Hooker shorty headers on my L98 motor. Now because the header on the right (passenger) side is so much thinner than a stock manifold is (as many of you already know), I can't get the dipstick tube to mount back up. If I push the tube over, the bracket gets too high and it won't work. Any tricks to doing this? ANY help would be greatly appreciated. Thanks.
I cut the bracket off of the dipstick tube on mine. I had a friend feed it in from the top and I guided it into the hole. We had to pull it back out a few times here and there and make some bends to get the angle right. Once it got in about a 1/2 inch, a few LIGHT taps with the shop hammer got it in the rest of the way.
Robert
1989 GTA TRANS AM
Was a TPI 305 & t-5 car.
Is now 383 stroker w/ the same T-5
World products Sportsman II heads(64cc fast burns). Lunati pistons@10.5:1 and 452/462/112* camshaft. Eagle crank and 6 inch rods. Ported/polished/port matched stock TPI intake. T-5 on a suicide mission.
Robert
1989 GTA TRANS AM
I got the Edelbrocks, and they came with two clamps: a big one for the header and a little one for the dipstick. You put the big clamp around the header and feed the bolt through the header clamp and the dipstick tube clamp and tighten them together. It was a pain to get to work but so far it seems to be working good.
Jason
Jason
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
GTARob me and a buddy did the same thing!i zip-tied so to make sure it didn't move after that
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
1992 Trans Am
May 10, 2023 07:19 PM
