Throttle sticks wide open!
Old Nov 12, 2004 | 01:21 PM
86IROCKET-Z's Avatar
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
Today, i went and washed my car at the shop..
When i went to leave, it had a hell of a time firing up, it kept starting and hitting 1500 and then just dying..
Finally, i got it to wake up, and drove it out of the shop..
I got out onto a small straight stretch and got into it..
I didn't punch it to the floor.
I went to let off the gas and it stuck wide open.. I hit the brakes and got slowed down (tires were smoking)and i shut it off.
Sat there for a minute and collected my thoughts..
Fired it up, and it runs fine again.. But this is the 3rd time that my throttle has stuck on me. I tried to get it to do it again, and it wouldn't.
I did a search, and i can't seem to find anyone who had the same type of problem..
Anyone have an idea what's going on with my car?
Old Nov 12, 2004 | 01:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Throttle cable binding at all?
Old Nov 12, 2004 | 01:28 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
lol I WAS going to say clean your carb, but because I read your specs, I dont know lol
edit: Oh, check your return spring?
Old Nov 12, 2004 | 01:38 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Yep. I have had throttles stick in a two cars... once could have been deadly... very scary. WIde open in fourth gear to hard braking into a corner and all of a sudden what the #%$@ stuck WIDE OPEN I shut it down and tried to drive through but two ditches and a bumper and two fenders, a rad, and a pair of underwhere and the drivers seat and all sorts of other nasties later it turns out there was a bent arm on the vacuum secondary diaphram linkage that got stuck under the Holley carb base. It would only get far enough down to catch when wide open
Second time the bushings were gone on the throttle body on my truck ( over 340k miles ) that caused the blades to bind into the side of the bores. luckilly in that case it was similar to yours only at medium throttle and a stomp or two on the peddle would release it. A rebush (sp?) of the throttle shafts was all it took to fix it up which is what I would check on yours providing the cable is moving freely of course.
I know of a local stock car racer who crashed and died from the throttle sticking. I would not be driving ANYWHERE until you get this solved. Good luck
Old Nov 12, 2004 | 01:43 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Something to look at also is the cruise control.
A friend had that happen to him in a thirdgen, it ended up turning into a high speed police chase that ended in a crash. He thought it had something to do with the cruise
Old Nov 12, 2004 | 01:46 PM
Engine: 7M-GTE
Transmission: R154
okay..
well i have to drive it down to the shop..
but i'll check out all the suggestions and see what happens..
thanks for all the help!
Old Nov 12, 2004 | 01:51 PM
ede's Avatar
ede
one things for sure it's only going to stick where you have it so that may be something to consider untill you get it fixed
Prodigious
Nov 7, 2020 09:23 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
