need Help everthing died instantly!!!!
Old Nov 12, 2004 | 04:07 PM
Sgt.D's92RS's Avatar
Car: 92 RS
Engine: 305 V8 numerous Mods:
Transmission: Auto+shift Kit 3.73 gears
Ok here is the jist of it. I was driving down the street when suddenly my dash went out and the engine died at the exact same
moment. I turned the ignition key and nothing happens. The windows won't even go up. The headlights still go on and the dome light goes on when the door is open but if you turn the key
you get nothing. I opened the hood and smelled an electrical burnt type smell. I looked under my open element air cleaner and the wire on top of the coil was exposed and touching the bottom of the air cleaner. I think this is the culprit. I replaced the coil but everthing is still dead.
Old Nov 12, 2004 | 04:38 PM
Vader's Avatar
Time to start tracking down the fusible links in the positive battery wire, and fusible links from the starter to the body harness. Don't overlook the ESC (Extremely Stupid Connector, according to RB83L69) that connects the fusible links to the body harness:
Replace then with the same size link, or you may not be so lucky next time.
Old Nov 12, 2004 | 05:06 PM
megaracerx's Avatar
thats what ya get for picking on those ricers you talked about over in the street racing board.
seriosly, sorry to hear that, i can say what it could be though...
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
