Is this normal?
Old May 31, 2001 | 11:25 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Is this normal?
Idleing the O2 volts are fomr 010-600 and everynow and then it will kick into open loop for 5 secs then go into closed again for awhile This only happens while idleing. Driving it always stays in closed loop.
89 FORMULA 350 Edelbrock Cat-Back ,March Pulleys,Super Coil,MSD 6AL ,Edelbrock TES's, AFPR ,Shiftkit, Edelbrock Base ,AS&M Runners, Edelbrock Waterpump, MSD 22# Injectors, Hoping for 13.5
Old May 31, 2001 | 03:31 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Seems like a lazy O2 sensor, or maybe you're using a standard O2 sensor with headders? A heated o2 sensor should cure it.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
