car suddenly dies while driving
Old May 31, 2001 | 03:18 PM
BlackZee's Avatar
My car has been suddenly dying on me when I am driving. Sometimes it restarts as I am rolling down the street, other times I have to pull over and stop before restarting. What could be causing this? A bad MAF? I have an '86 Z28 with mass air TPI.
Old May 31, 2001 | 03:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Need to go thruogh the basics first...fuel filter, cap/rotor, etc...
Does the car just stall, or begin to cutout then die? If it's cutting out, does the SE light come on during the miss, or not?
Have you checked the ECM for codes throught the ALDL connector?
Old May 31, 2001 | 03:31 PM
BlackZee's Avatar
Only 1000 miles on fresh tuneup, no "check engine light", and no warning!
Old May 31, 2001 | 03:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, to eliminate the MAF, unplug the electrical connection on the underside of it.
Do you have access to a fuel pressure gauge?
Once the MAF and fuel pressure have been eliminated, you need to look into the ignition as a possible problem as well.
Also, you could be getting EGR at idle as well...an open EGR valve, or partially open one, will cause stumbling and stalling as well.
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
