Weird problem, NEED HELP!!!
Old Nov 13, 2004 | 09:19 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I was on my way to the Zephyrhills Auto Fest today and just as I was about to pull into the main entrance I started to smell gas fumes and I could also hear the fuel pump starting to make a loud groaning noise. The car started to sputter and then it finally died. When I pulled over, I tried to start it up and the engine just sputtered and died again. When I turn on the ignition i could hear the pump prime but it didn't sound right. It didn't sound like the constant high whine then cutting off. It sounded high pitched whine and gradually went to a low groan then cut off. After several times trying to start the car, I decided to release the pressure by opening the gas cap. After the pressure released I closed the gas cap again and started again. The car started just fine and the fuel pump sounded normal again. After leaving the car show, I drove home with no problems at all. This is the second time this has happened with the same exact symptoms before the engine dies; gas fume smell along with low groan from the fuel pump and engine shuts off. My car is a 305 TPI. Has anyone else had this problem?
Old Nov 14, 2004 | 12:40 AM
sellmanb's Avatar
Car: '86 Berlinetta
sounds like your fuel pump is on it's way out. Or the fuel pump's pickup is loose or something, and then when you de-pressurize the gas tank, it'll sink it back down.... or something like that, I dont know.
I remember reading in a post somewhere though that from the factory our cars didnt have that "hiss" when you open up the fuel cap, to release the pressure. It's a problem of some sort.
Old Nov 14, 2004 | 07:27 PM
Morley's Avatar
No, the hiss from the tank is normal and happened with my car from day 1.
You need to look into replacing the pressure relief valve. It is a plastic device hooked to the tank lines and located up under the car near the filler neck.
Old Nov 14, 2004 | 08:27 PM
pwdbychevy's Avatar
Is this valve white in color? The only thing I saw under there is a white breather looking thing clamped to the end of a rubber hose. Is that the pressure relief valve? Where can I buy that? Have you had this problem also? I just changed the fuel filter today. I blew into the old filter and it was very restrictive compared to the new one.
Old Nov 14, 2004 | 09:22 PM
Morley's Avatar
That's the one. It is a dealer only item, as far as I know.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
