1988 305 TPI to 350 TPI
Old Nov 14, 2004 | 06:57 PM
sawsntools's Avatar
I have a 1988 305 TPI and obtained an almost new 350 crate engine real cheap. I would like to swap the 305 for the 350. I know I need different injectors and apparently a 350 knock sensor. Since the 305 and 350 fuel rails were different part #'s do I need 350 fuel rails as well or do the ones I have work fine with the 350 injectors?
Old Nov 14, 2004 | 06:59 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
engine swap thread would be a good place for you to look.
i belive all tpi's 305 350 are the same , just injectors and knock sensor as you mentioned.
jeff
Old Nov 14, 2004 | 07:19 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
The only thing you will need to change from your TPI intake manifold on up is the injectors. Everything will bolt just fine on the 350.
Old Nov 14, 2004 | 09:24 PM
sawsntools's Avatar
thanks a lot
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
