Leaking valve cover or intake?
Old Nov 14, 2004 | 08:55 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
I noticed some puddling oil on the passenger side lower intake. Is this from a leaky valve cover or the lower intake? If it is the lower intake is that from oil seeping up the bolts? If I end up replacing the lower intake do I need to RTV the entire surface of where the lower intake meets the heads and the block or can I get away with just RTVing the ends of the block? Thanks for any help.
Old Nov 14, 2004 | 09:00 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Really need to clean it up really good and pinpoint the source. I'd first guess it's coming up through the bolts, real common. But, again, I'd try to find the leakage spot first.
Old Nov 14, 2004 | 09:03 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Yeah I think it might be the bolts too. The oil doesn't seem to be anywhere else except on one spot of the intake. I would almost think that if it was the intake gasket that it would be leaking radiator fluid too. Is it necessary to replace this gasket or just thread seal the bolts? Also how is everyone else sealing up there intakes? Thank you.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
