Help, Lineup Top Dead center and this is what happens
Old Jun 1, 2001 | 06:30 PM
Kyle F's Avatar
OK in an earlier post I said tha whn the rotor lined up to the #1 cylinder location the harmonic balancer was about 20-30* past straight up. So my brother and I bolted everything back up an tried to start the engine up. It fied an rav very rough, but it began to run properly as we turned the disributor Counter Clock Wise to about 90* and ran fine, but the SES light was on, Probably because of the EGR missing, and when we reved it up it would backfire at about 2500-3000RPMs.
So where have we went Wrong? SOmethings Not Right, please give us any Ideas on what may be wrong.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 1, 2001 | 06:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What engine is this?
ICON Motorsports
Old Jun 1, 2001 | 06:55 PM
Kyle F's Avatar
89 305 TBI with LT4 cam and new heads, its Brian Felts' car.
Old Jun 1, 2001 | 07:11 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Does it lug when you first tried to start it?
May be your distributor is off by a gear. Take it out and move it a tooth and see what happens.
Also possible your damper's outer ring is starting to spin. how old is it? What does the rubber ring look like on the damper?
Old Jun 1, 2001 | 08:07 PM
FastBroker's Avatar
Get a timing light!!!!!!!!!!!
Old Jun 1, 2001 | 10:16 PM
jms's Avatar
jms
Is it possible you have a 350 balancer on there? Most 305 balancers are hollowed out on the back side and are timed at about 12 o'clock. Most later model 350 balancers are solid and have the timing stripe at about the 2 o'clock position. The 350 balancer fits but the timing mark is usually in the different location.
jms
Old Jun 2, 2001 | 07:27 AM
ede's Avatar
ede
what have you done to of "bolted everything up", just intake swap? if you've not changed the cam or gears set the dampner mark on 6* with #1 on compression stroke and the rotor pointing to #1. use a light to set the timing with est unplugged.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
1992 Trans Am
May 10, 2023 07:19 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
g.l.mos
Aug 22, 2015 12:02 AM
