New camshaft installation questions
Old May 31, 2001 | 04:12 PM
BahamutRS's Avatar
I was looking into installing a new Comp Cam nitrous HP camshaft in my 1992 Camaro RS. If I get one, aside from the camshaft installation, what else do I have to do? Does anything have to be programmed in the computer or anything? I really don't know, so maybe someone can help me out. Thanks!
Old May 31, 2001 | 04:18 PM
Dan87IROC-Z's Avatar
You will need to get new valve springs, retainers and valve seals. Along with those, you will need new intake, timing cover, valve cover and probably head gaskets. You will need new supplies of oil and coolant along with a new timing chain set. Expect to spend a good deal of money and a fair amount of time on this project.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Jun 1, 2001 | 02:25 PM
Damon's Avatar
Dan's right. If you want to do it right then that's what you need to do. If the cam is an aggressive one then yes, you will also need to have the ECM reprogrammed if you expect any power gain for all your effort.
Old Jun 2, 2001 | 07:41 AM
ede's Avatar
ede
also there is a chance to take advantage of the cam you may have to go to larger injectors and an AFPR, if you don't have them now.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
