About to give up...
Old Nov 18, 2004 | 09:27 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
About to give up...
Hey guys,
Still on my quest to pass the NOx portion of the emissions test. I am currently double what the limit is. I have heard that the EGR system needs a little exhaust backpressure to fuction properly. I wonder if I have too little backpressre for it to work right. LOOK at my Sig for my mods.
This is what I have done so far:
-NEW EGR Valve
-NEW Plugs
-NEW Wires
-NEW 02 Sensor
-NEW Distributor Cap
-NEW Rotor
-NEW Vacum ines
-NEW Catalityc Converter
-CLEANED EGR passages
-SET timing at all different locations (NO HELP)
-SET fuel pressure at all different levels (NO HELP)
-CHECKED for vacum @ EGR valve (15inches during operation)
-ALWAYS ran premium fuel
What do you guys think? Is there some other avenue that I havent tried? How about the backpressure thing? Does that sound like a good idea?
Old Nov 18, 2004 | 10:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
How did you go about cleaning the EGR passages?
What type is the new EGR valve - same as original?
Old Nov 18, 2004 | 11:05 AM
JerseyMark's Avatar
Engine: 96 LT1
I used a bottle brush to clean the passages... But I dont even think they were dirty. While the car was ideling, if you push up on the EGR diaphram, the engine bogs. So I have to assume the passsages are good.
I dont know the manufacturer. I got it from pep boys for like $60-$70
Old Nov 18, 2004 | 07:01 PM
five7kid's Avatar
Reason I asked is some are called "positive" pressure type, and require some pressure in the exhaust side to close a check valve in order for the vacuum to open the valve. A replacement valve can be of either type.
How did you go about setting the timing?
Old Nov 18, 2004 | 08:29 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
well don't do this but my uncle to get cars to pass in colorado he just adds some (methane... mothonal.. shyt i can't rember brain fart) to his tank and dirve around for a bit so it mixes he hasn't had car not pass that way
Old Dec 4, 2008 | 03:40 PM
JimmyS301's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: LB9 5.0L H.O.....for now
Axle/Gears: stock 3.42
Re: About to give up...
do you mean methanol by any chance?
Old Dec 5, 2008 | 05:59 PM
JerseyMark's Avatar
Engine: 96 LT1
Haha... Atleast people are using the search feature. This post is over 4 years old!
Do we have a new winner?
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Linson
Oct 1, 2015 09:50 PM
