will 87 L98 alum. heads bolt to 91tpi motor
Transmission: A4
I may be able to pick up a pair of 87 corvete aluminum heads for my 91z28 tpi motor
will the bolt pattern be the same on the heads as my intake. i know gm changed this but don't know what year. will they work. if not then what year aluminum heads do i need to look for
Transmission: A4
what do you mean grind away at it. where on the intake do i do this. i just ported my intake and dont want to buy another one. is it easy to make it bolt up without any problems
What he means is that the center two bolt holes on the corvette heads are at a different angle than the intake. You will have to either grind down the intake to get them to fit or find a lower TPI Corvette intake.
Transmission: A4
that seems easy. my dad is a machinist and does that all day long. is that all i need to do. everything else will bolt up. will these heads offer more horsepower or should I just save MORE money and get better heads. I already have a LT4 HOT cam waiting to go in. the entire TPI system is ported and polished and gasket matched.
<font face="Verdana, Arial" size="2">Originally posted by BOTTLEDZr28:
that seems easy. my dad is a machinist and does that all day long. is that all i need to do. everything else will bolt up. will these heads offer more horsepower or should I just save MORE money and get better heads. I already have a LT4 HOT cam waiting to go in. the entire TPI system is ported and polished and gasket matched.</font>
355tpipickup
Aug 25, 2015 12:54 AM
