i.d. heads
Old Nov 18, 2004 | 07:31 PM
kamaroirock's Avatar
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
i.d. heads
need help finding out what heads i have on my 355. the i.d. #'s are found on the driver side head on the back right? and i can take those #'s to that mortech.com site right?
Old Nov 18, 2004 | 07:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The #s are on every head, under the valve cover. The heads are (were at least, and should be) identical. No "driver's side" and "pass side", that's only where they happen to be installed.
www.mortec.com/castnum.htm
Old Nov 18, 2004 | 07:45 PM
Engine: ls1, 4.0L
oh ok, thanx
Old Nov 18, 2004 | 07:57 PM
Engine: ls1, 4.0L
are you sopposed to replace the valve cover gaskets every time you have remove the valve covers or is it only when they start to go bad?
Old Nov 18, 2004 | 08:16 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
depends greatly upon which kind of gaskets you have ....if they are the rubber ones you can usually reuse them a couple times
if they are the cork ones you might as well replace them they are cheap but you can get away with reusing them if they dont have sealer on the side that meets the head ....
when and if you do this the head casting #s can be found at www.mortec.com/castnum.htm
Old Nov 18, 2004 | 08:26 PM
Engine: ls1, 4.0L
ok, thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
