anybody know where to get a 1.5 self aligning roller rocker arm?
Old Jun 1, 2001 | 12:17 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I've been looking for these for a 3/8" stud. Can't find 'em. Anybody know where? Didn't see 'em in Summit. Need them for my L31 Vortec heads, just finished porting them. Buying springs and I'll probably use the GM pushrods since they're all OK, as I will use the lifters, too.
Depending on the cam, I may want to use a set of 1.6 on the exhaust side.
Old Jun 1, 2001 | 12:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Crane makes them. about 299.99 summit has them in there book on page 72 (newest book) pt # CRN-10751-16
Old Jun 1, 2001 | 01:37 PM
NTChrist's Avatar
Proform makes a self-aligned, full-bearing roller rocker for 160-something. Looks like a big rocker, though. Probably would have to get bigger rocker covers.
They might not be as strong as the crane golds but they're more than $100 cheaper.
I saw it in the latest Jeg's cat.
No guts, no glory.
Old Jun 1, 2001 | 03:33 PM
ede's Avatar
ede
comp
1.6 pn 1318
1.5 pn 1317
about 320 from jegs
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 1, 2001 | 04:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Don't forget about Comp Cams Magnums. They don't have a roller fulcrum, and they're steal, but they are inexpensive and strong. That and they do provide clearance for the stock covers. I've read they're worth 10-15hp.
EDIT- They got them in Jeg's. They are about $200 a set and are also available in 1.6:1.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited June 01, 2001).]
Old Jun 1, 2001 | 07:13 PM
dhirocz's Avatar
I'll look into proform, if they're any weaker or less desirable I'll get either the Crane or Comp's. Anybody have experiences with these? durability, performance?
Thanks for the help.
Old Jun 2, 2001 | 10:38 PM
NTChrist's Avatar
I haven't actually used a proform rocker, but logic says that a big aluminum rocker on a street engine is not going to break, especially if the stock rockers are still alive on the engine right now.
IMO 1.5 roller-rockers do free up hp, but are usually overkill on a street engine. Unless you're going to go for the cheap rollers, save your money.
1.6+ rollers are usually a different story...
No guts, no glory.
Old Jun 2, 2001 | 11:01 PM
Joseph@SDSC's Avatar
I run 1.6 Proform full roller under stock centerbolt valve covers, one is with .525" lift. Have no clearance problems, but its probably real close
I haven't tried the self-aligning ones yet, I run pushrod guideplates, so their not needed here.
-Joseph
ASE Master Automobile Technician
Scoggin-Dickey Chevrolet
1967 Camaro (Vortec Heads, GM Vortec Intake, ZZ4 roller camshaft) --- Planning T-56 Install in the near future
1992 Firebird (Weiler Vortec Heads, LT4 Hot Cam, GM Vortec Intake, 3000 Stall, 3.73's, Auburn Posi)
Old Jun 2, 2001 | 11:19 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i know of some one that had a ProForm roller rocker break in half
stay away from ProForm
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 3, 2001 | 12:46 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I use the 1.6 Proforms on my vortecs and use guideplates with no problems.
Old Jun 3, 2001 | 09:10 AM
dhirocz's Avatar
What about roller tip rockers? I have started thinking about an LPE cam, and if the exhaust side doesn't have high enough lift, I'll probably install 1.6 on the exhaust side. I've always used roller rockers, but truthfully, how good are the roller tipped ones? Anybody use 'em? Are they really that durable?
Old Jun 3, 2001 | 09:11 AM
dhirocz's Avatar
I have all the factory Vortec stuff like valvecovers anyway, and wanted to use those if possible to save some $$$.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
