???idk what to do
Old Nov 20, 2004 | 10:42 AM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
???idk what to do
I recently put a 350 in my camaro its a 1992 rs, i having some problems with it , it will idle pretty good and everything but when i go to put it in reverse it will catch but die really quick and its the same for drive, it acts like its not getting enough power to turn the wheels or something but idk could some give me some advice as to what it could be.
Old Nov 20, 2004 | 11:22 AM
ljnowell's Avatar
More details? Induction system, fuel system, ignition system. Does it spit and sputter and die, does it just shut off? If fuel injected, any codes? Have you checked the fuel pressure or fuel filter? Is the idle high enough? Just throwing some ideas around, but it will be impossible to tell anything without more details on the problem.
Old Nov 20, 2004 | 11:41 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
My car used to stall out a lot when I put it in reverse and when the wheel was turned all the way to one side. It ended up being a few vacuum leaks and once fixed, the problem went away.
Just a thought.
Old Nov 20, 2004 | 03:07 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
its carbed has a holley 600 which is pretty old ive replaced the jets and gaskets in it including the power valve, its has an accel ditributer with coil on top the block been bored .60 over. Ive checked for all vaccums leaks couldnt find any even replaced all the vaccum hoses with new hoses. It will back up everyonce in awhile and move but i will have to feed it a bunch of gas to get it to go anywhere its the same for drive also. um.... when it does die it just dies like the car being shut off. its just and instante stop but i can feel the wheels catch just before it dies, if i want to get it to move anywhere at all i have to rev it up to about 3500 rpm to get it to back up. idk if this helps out alot but if u can get anything from that thanx
Old Nov 20, 2004 | 03:28 PM
Nate86's Avatar
Engine: 4 cylinder
Did you check to make sure the plug wires are connected to the right plugs?
Old Nov 20, 2004 | 03:32 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
Yeah ive gone over them many times
TheExaminer
Sep 28, 2015 02:28 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86iroczwv
Sep 3, 2015 06:21 PM
theurge
Aug 21, 2015 12:46 PM
1985chevydude
Aug 20, 2015 12:29 AM
