Bad electrical problem, need help....(long)
Old Jun 3, 2001 | 01:27 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
OK, did a tuneup on my car last night. taking out one of the plugs above my starter and the ratchet hit one of the screws on the back of the starter and shot sparks all over the place so i pulled my hand away. well the ratchet stayed touching the spark plug and the starter and it welded itself to the starter bolt. Got a crow bar and got the ratchet off. finished the rest of the tuneup including putting a heated O2 sensor in. Roll the car out of the garage. turn the key it cranks slow for half a crank and then starts up normally. drive the car up to dominicks, runs great. shut it off and go inside, come back out and go to start the car. cranks halfway and i lose all power. abosluly nothing would power up, no lights, horn anything. leave it there and come back this moring. i get there and the alarm light is blinking. go in turn the key, nothing. take the battery out and go to pepboys, they check out the battery after recharging it and say that it is fine. put the battery back in the car, nothing, no power again. call AAA. while im waiting for them to come the alarm starts to squeak a little like its trying to go off but it doesnt have enough power. after a while i put the key in, turn it to on but dont start it. the fuel pmup comes on, all the dash lights light up. i turn the key and everything dies again. try to jump it off my dads jeep, no dice still no power to anything again. the tow truck gets there. he hooks his jumper cables up turn the key to on fuel pump and all the lights come on again, hit the key and it all dies again. try it again and the starter clicked a few times this time but then it went dead again. try it once more and now no power again. got the car home, she is in the garage right now. any idea whats wrong???????? i think either the battery really is jacked and the pepboys test was wrong or something melted in the starter and its shorting everything out.any advice??? thanks very much.
1988 IROC-Z L98
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, Removed MAF Screens, MSD-6A, MSD Blaster 2 GM Coil, bored .030 over, Other minor mods
Suspension Mods:
Lakewood Traction Action Lift Bars, Hal Rear Shocks
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit , Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)
ET: 13.833@99.30
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
www.mfba.org
Old Jun 3, 2001 | 01:44 PM
MeanYellowZ's Avatar
you definitely shorted something out man. The smaller wires that run from the power connection on your starter are what give power to the car, check to make sure that none of those burnt up, obviously make sure the main power cable didn't get completely ruined, I personally would buy a new battery cable, and run new wiring up from the starter and splice it in near the fuse panel and eliminate the chance that those wires burnt through completely somewhere along the way.
Old Jun 3, 2001 | 02:39 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
https://www.thirdgen.org/messgboard/...ML/002890.html think its a fuseable link?
Old Jun 3, 2001 | 02:43 PM
Like a ROC 89's Avatar
What brand and part number of the heated O2 sensor did you get? Where did you splice into the 12volt ignition source?
Old Jun 3, 2001 | 05:23 PM
yeah that is included in the wiring coming up from the starte powering the car. If your wiring doesnt look all burnt and messed up it may just be the fusible link. Myself, Im not crazy about those and usually replace the wiring with new wire and use a heavy duty circuit breaker. I reran all the wiring on the outside of the firewall on the yellow car
Old Jun 4, 2001 | 11:23 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Thank you everyone very much for your help. The car is back and running!!! my dad worked on it today while i was at class and got it running. he cleaned off all the termials on the starter and the battery and it fired right up. talk about missing the obvious. i think the battery was dead too so that didnt help either, but its all charged up and running great. Since i had just finished the tune-up, she is pulling like a madman. I really wouldnt be surprised if i ran a 13.5 next time at the track. thanks again for the help.
Infested
May 22, 2018 11:56 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Bryan F
Aug 18, 2015 02:28 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
