So - Heads, Intake, or Cam first?
Old Jun 5, 2001 | 11:29 AM
91RedBigFinZ's Avatar
What should be done first in your guys opinions? Thanks, Doug
Central Indiana Camaro Club member since Oct. 2000
1991 Z28 - 51,000 miles.
Dyno Results: 226.4 Max Hp; 310.4 Max Torque (ft-lbs)
All power options leather. 350 TPI:
K&N; Airfoil; Custom 'Ram-Air'; Slp Runners;Poweraid TB spacer;
Fastchip;
SLP Headers; Borla Catback 50% open; Dual factory Cats;
March underdrive pulleys;
Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs;
Manual fan switch;
TB coolant bypass; smog pump delete
Spohn subframe connectors (black powder coat);
Pirelli P7000 Z245/50/R16 all season tires;
Energy suspention motor mounts
S Cobra Radar Detector; Z28 SS Floormats;
Technalon IV car cover (now on my dad'a 2000 Berger SS).
Old Jun 5, 2001 | 01:41 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
are we talking about the TPI in the sig?
If so, it sounds like you already have runners.I would just port your upper intake, get a set of heads and cam at the same time.
Old Jun 5, 2001 | 07:28 PM
Yeah.. a TPI. I thought about getting a new intake, and having all of them port matched. Heads and a Cam would be next i guess. Doug
Old Jun 5, 2001 | 07:44 PM
Vader's Avatar
91,
This is just my opinion, but I believe the biggest single performance improvement dollar-for-dollar has to be the installation of a good camshaft. The heads will accomodate more flow than the stock cam profile creates. The intake will perform better with an improved cam profile, and the headers and all the other external mods you have done will come alive with a new cam.
s
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 5, 2001 | 08:58 PM
Thanks, Vader. What is a good cam to get, then? I was looking for one similar to the TPIS ZZ9. Will I have problems with my current heads and the higher lift (clearance) ? Should I wait to get new rocker arms until I get heads to make things more cost effective? Thanks, Doug
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
