engine ground strap
Old Nov 27, 2004 | 09:19 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
engine ground strap
has anybody ever forgotten to attach the ground strap from the back of the head to the firewall and if so, what happened when you tried to start the car?
Old Nov 27, 2004 | 09:26 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
if you also don't have a ground from the battery to the body you get a bad voltage drop & that can cause all kinds of problems
Old Nov 27, 2004 | 09:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I forgot mine. A shower of sparks flew out at me when I hooked up the battery. A subtle reminder to check all the major grounds.
Old Nov 27, 2004 | 09:53 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It's always a good idea to have a direct ground to the engine.
Otherwise: Snap, crackle, pop, **** crispies.
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
dayum...was not aware of this. i have been having voltage problems for a while now.
how do i go about grounding from battery to body?
Old Nov 27, 2004 | 10:05 PM
DENN_SHAH's Avatar
White91GTA, just a small wire, about 10 gage or so from the negative side of the battery to the fender.
i have seen a ring & pinion get eaten up from not having a battery to body or a motor to body ground. why the guy wasn't having other problems i don't know.
Old Nov 27, 2004 | 10:10 PM
White91GTA's Avatar
Engine: 5.7L TPI
DENN_SHAH...thanks for that info. I will have to look at my car and see if I have the ground there or not and if not I will definately be putting one on there.
Old Nov 27, 2004 | 10:16 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Make sure you have a ground directly from the block to the battery, that the bet adivce i can give.
Old Nov 27, 2004 | 10:35 PM
DENN_SHAH's Avatar
no problem
grounds are 1 of the first things i check on electrical problems.
like ME Leigh said, the big cable from the battery to the motor, it needs to be able carry at least 500 amps, a good ground from the motor to the body & a good ground from the battery to the body, all 3 are needed.
i have 2 grounds straps from the motor to the body on my car. with the motor running, everything electrical is powered by the alternator, so a single small wire motor to body ground won't last long with a 100+ amp alternator.
Old Nov 27, 2004 | 11:40 PM
CaysE's Avatar
There's no need for a direct battery to block cable. Put a 4-gauge ground from the battery to the frame, and another from the back of the block to the firewall.
While you're doing this, another good idea is to upgrade the alternator-to-battery positive wire to 4-gauge, as well. Try to keep the wires as short as possible, but well-routed.
Old Nov 28, 2004 | 01:25 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Absolutely, you want the shortest distance to ground for the ignition and starter circuits.
Old Nov 28, 2004 | 09:22 AM
CaysE's Avatar
I honestly don't see a point in running a cable directly from the engine block to the battery, unless you have no good grounding point on the frame because of excessive rust, or you have some ridiculously powerful ignition. You're not going to route a wire through the belts, so you have to run the wire to the back of the engine block anyway. A ground wire to the firewall from the block and a ground wire from the frame to the battery would do the same job.
Feel free to correct me if I'm wrong. I've just never seen it done that way.
Old Nov 28, 2004 | 12:42 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Because steel is not a good conductor of electricity.
Old Nov 28, 2004 | 03:03 PM
CaysE's Avatar
Good point
Old Nov 29, 2004 | 04:40 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
The factory does it that way, at least on my car it did.
I'd post a picture If I could get the Attach file option to work.
Old Nov 29, 2004 | 11:53 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its best to have the large gauge cable go right to teh block/head as the starter is the single largest load. Dont want it pulling current through the smaller ground wires hooked up to the engine.
Old Nov 29, 2004 | 09:17 PM
cormyr's Avatar
Engine: 383 miniram
agreed
BRoss99
Aug 10, 2025 05:08 PM
E Rod
Aug 28, 2015 05:17 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
