Base timing jumping at idle?
Old Nov 28, 2004 | 05:58 AM
FireBoid's Avatar
Car: 1987 Firebird, 1997 Camaro
Engine: 2.8L, 3.8L
Transmission: T5, 4L60E
New Accel Billetech distributor. When I disconnect the set timing wire and attempt to set the timing, it jumps toward advanced with the idle surge. There's no mechanical or vacuum advance in HEI. What could cause this? Can't get the idle to settle down either. Think they're related.
Bill
Old Nov 28, 2004 | 06:16 AM
FireBoid's Avatar
Engine: 2.8L, 3.8L
Forgot a few things that may limit the number of questions;
New Jeg's performance ICM
New MSD Blaster coil and 8.5mm Super Conductor wires
New cap and rotor
Connectors all cleaned and inspected
Old Nov 28, 2004 | 10:09 AM
Vader's Avatar
That symptom sounds typical of a worn distributor, but the new distributor shouldn't have that problem. There may also be some spark scatter from excessive spark voltage, an incorrectly keyed distributor cap or rotor, or a problem with the pickup coil, again, which shouldn't be a problem with the new distributor. Ignition timing at idle in EST bypass mode should be rock steady, as you know. Which connector did you disconnet to set the timing? I know the V-6s are a bit different.
Old Nov 28, 2004 | 06:16 PM
FireBoid's Avatar
Engine: 2.8L, 3.8L
I used the EST bypass.
Old Nov 28, 2004 | 08:25 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
worn timing chain?
Old Nov 29, 2004 | 04:53 AM
FireBoid's Avatar
Engine: 2.8L, 3.8L
Brand new motor. Only has about 2 hrs on it. I know, got me baffled too.
Bill
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
