loud rattle from engine bay
Old Nov 28, 2004 | 09:12 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys .i have this rattle noise coming from my engine bay.lets say when im in idle at a traffic light the rattle will come and go.also as i give lil gas off the light it will also rattle,wat can this noise be?
Old Nov 28, 2004 | 09:22 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Wow, could be anything, my first thought is possibly torque converter bolts are a little loose, I'm assuming its an automatic.
onebinky's Avatar
Check out the heat shields on the manifolds and the cat, probably rattling from the engine viberation at idle.
Old Nov 28, 2004 | 09:26 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
tranny jst got rebuilt like 2 months ago and i have headers and no cats
Old Nov 28, 2004 | 09:32 PM
87tpi7749's Avatar
Engine: 5.7L
All the more reason to check those converter bolts. A loose converter usually makes noise in gear idling not in park, so your symtoms fit.
Old Nov 29, 2004 | 12:25 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
well i guess it wont hurt to check them but i dont see how that will get loose or make a rattle noise wat else can it be?
Old Nov 29, 2004 | 01:59 AM
Disifer's Avatar
Car: 1989 trans am
Engine: 305 tpi
Transmission: automatic
What if it rattles in park? Just noticed mine doing it tonight. At stoplights and just sitting in park. Probably heat shields?
Old Nov 29, 2004 | 04:52 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
mines has never rattle in park only in gear
Old Nov 29, 2004 | 07:26 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
could it possibly sound like bearings rolling around in a pulley? cuzz i have a rattle that sounds like its coming from a pulley
Old Nov 29, 2004 | 10:23 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
thats wat ive always thought it can be
Old Nov 29, 2004 | 10:27 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
i buddy of mine has a 90 firebird, makes the same noise....sounds like this could be a common problem, hopefully that would be the case and someone would be bound to have a explaination or way of stopping it
Old Nov 29, 2004 | 11:12 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
how can u find out if its a pulley bearing?
Old Dec 4, 2004 | 03:48 PM
Poncho Villa's Avatar
Car: Badass 1991 Firebird
Engine: Screamin' 305 TBI
Axle/Gears: 2.73, 3.42's waiting to go in!
My Bird has developed a strange squeak/rattle too, mostly on warmup when the engine vibrates at a certain rpm, and coming to a stop, like a bad tranny or motor mount. Could also be a pulley--having it checked out next week.
The way to tell if it is a pulley is to use a socket wrench and crank back on your idle tensioner--holds the 'do nothing' pulley on your serpentine belt (there's a square hole on it to fit a socket wrench end, 1/4" I think ) then try starting the car without the belt and listen. Don't run it for long though, because you have no water pump, etc. * Also, try this at your own risk, as a mechanic told me to try this, but I have not done it. Makes sense, but again, you'll have no water pump, or alternator, etc. *If anyone thinks this is an extremely bad idea please say.*
Also, the idle tensioner itself will rattle like hell when worn, cheap to replace. Good luck, and I will post when I find out what my weird noise is.
Old Dec 4, 2004 | 07:14 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
awesome keep me updated
Old Nov 17, 2006 | 02:55 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
mine was doing the same exact thing so i just replaced my timing chain and waterpump, when i got the cover off there was a stupid amount of slack in it, now if i could get the serpentine back on i could tell ya if that was the problem, im sure it was tho
Old Nov 17, 2006 | 04:44 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
i have a new motor
Old Nov 17, 2006 | 09:55 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
yea i just replaced the timing chain and waterpump, its running good, but the noise got worse..
Old Nov 17, 2006 | 10:49 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I had a rattle in the front end of the transmission, flexplate, torque converter area of my GMC Jimmy for about 3,000 miles before the rear main bearing in the 2.8 spun. I put a rebuilt 3.1 into it. The noise was still there. One week and 400 miles later, the transmission's pump croaked. No line pressure at all.
Old Nov 19, 2006 | 01:14 AM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
i dont know about everyone else but mine sounds like its coming from the exhaust on the passenger side, like somethin is hitting, it gets real bad then i just give it a little gas and hold it at ~650-700rpm and it goes away... but besides that everything runs great
Old Nov 21, 2006 | 09:17 AM
eruk's Avatar
Car: 85 iroc, 96 z28 ss, 03 Silverado
Engine: 305, lt4, lingenfelter ls2
Axle/Gears: 3.08, 3.73, 4.10
same problem its made a rattling sound with 2 different trannys in it.
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
