Removing emmissions crap as well as A/C stuff
Old Nov 29, 2004 | 09:22 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Okay....i want to remove all the emmissions and A/C crap from my engine bay, mostly because i want a very clean engine bay, but also because none of it is hooked up (at least most of it isnt) and its just wasting space.....how do i remove all the AIR stuff? what do i need to do/buy to completly get rid of the A/C?
Thanks,
-Chris
Attached Thumbnails Removing emmissions crap as well as A/C stuff-enginebefore.jpg
Old Nov 29, 2004 | 09:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
First things first. Get rid of the evil filter foam triangle. All it takes is one good backfire and the foam melts up, gets sucked into your engine, and kablamo.
As for the rest, sorry, all I know is the AC delete pulley. I just had to give my 2c on the air filter.
Old Nov 29, 2004 | 11:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Old Nov 30, 2004 | 04:47 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Start with the heater blower motor, all the plastic, the heater core...Lots involved....maybe this will help? I have no ac/heat/smog either.
I Can take more pictures of it will help. This was to show someone how to bypass the heater core...
Then you will want to make a block-off panel like this to get rid of the now useless controls...
Where in MA are you? I lived in Marblehead for 11 years, was born at Mass general.
Old Dec 6, 2004 | 11:29 AM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
Well I have a bunch of guys that can help you out if you go over to my site in my sig. Anyways here is a pic of mine...
Old Dec 6, 2004 | 11:32 AM
BIGJON's Avatar
.....and no I don't have the "triangle of death" anymore....
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Aug 28, 2015 05:57 AM
anesthes
Aug 26, 2015 01:37 PM
3rdgenparts
Aug 8, 2015 07:09 PM
