305 Shut Off While Driving And Wont Crank.
Old Nov 30, 2004 | 11:02 AM
FORMULA75's Avatar
Car: 1984 FIREBIRD
Transmission: AUTOMATIC
305 Shut Off While Driving, timming off ????
I have an 84 Firebird with 305 4BBL quadrajet Automatic.
Yesterday on the way home noticed slight rattling noise.
Noise went away and returned 3 min later. Before I could pull over or put car in nuetral. it shut down.
Pushed car 1/4 mile home.
I did notice slight loss of power before 1st rattle.
Car has 130,000 miles. Any idea where I should start.
Thanks. Formula75
Old Dec 1, 2004 | 10:28 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have an 89 RS 305 daily driver, and one day it lost power and shut off while I was driving. It turned out to be the ignition module in the distributor.
Old Dec 1, 2004 | 10:50 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Can you turn the motor over with a breaker bar ????
Old Dec 1, 2004 | 10:53 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
yeah make sure it wasn't an oil issue and the motor didn't freeze. Like mentioned try turning the crank by hand
Old Dec 1, 2004 | 11:10 PM
87CobraKiller's Avatar
Do you still have power? Maybe you have a loose wire at the battery or starter. Starter could be loose and not grounding. That noise could have been the starter ratling around if the bolts have loosened up on it.
Old Dec 1, 2004 | 11:33 PM
TTOP350's Avatar
yes, do the simple checks first
Old Dec 2, 2004 | 12:14 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
i know on mine when i was going up to the mountains on a hot day my car died and didnt start. i barley mad it home and thats were it died. it turn out to be the pick up coil and the starter. check that.
Old Dec 4, 2004 | 09:31 AM
FORMULA75's Avatar
Car: 1984 FIREBIRD
HOT CHICK NEEDS HELP
12/03/04
So far I have replaced timming chain ,gears, and Electronic Ignition Module. Still no start.
I set upper gear with "dot" at top of gear with # 1 cylinder at TDC. This is what 2 seperate repair manuels said to do.
I am being told by others that the repair manuels are wrong and the top gear should have "DOT " at bottom of gear.
I spent 12 hours to do the chain and gears please tell me the repair manuel did not lie to me.
Engine started and sounded great for about 4 sec and shut down now turns over and sounds like its going to start, almost acts like its flooded.
HC
Old Dec 6, 2004 | 03:38 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
fuel pressure?
gta90
Sep 15, 2015 04:00 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Fronzizzle
Aug 9, 2015 01:15 PM
