Spare tire replacement???
Old Jun 6, 2001 | 12:48 PM
Z28Man's Avatar
This may be a wierd question...I have a aluminum spare with crappy tread and a stock spare tire that has never been used. My question is, can a tire shop switch the rubber on deflated spare tires? I would love to have brand new tread on my spare.
Old Jun 6, 2001 | 12:58 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If the tires are the same size, then why not just switch tires??
As long as the tread width is the same, then it could be done. I don't know about cost, and generally speaking, re-treaded tires are not good.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jun 6, 2001 | 01:23 PM
Gta-Paladin's Avatar
My 3 day old Comp T/A 255 had a screw in it and i had to take it off to get it down to the shopand i must say WHAT A PAIN IN THE ***
First off what was the general thinking?
I had to unscrew the panels in the trunk with a screwdriver that i dont have in my car.. luckily i was in my garage. Then i had to undo about 25 wingnuts to get everything out when i finally found the jack points got the car jacked 30 min later and started taking the nuts off i realized something the tool that was taking the lugs off had rounded innards and wouldnt take the lugs off. so i had to call AAA and guess what they got it off and as we went to put the spare on i cried the SPARE DIDNT FIT OVER THE GTA's CALIPERS IN THE REAR I almost cried i tried it on reverse to no avail i am mad
Old Jun 6, 2001 | 02:12 PM
Xenodrgn's Avatar
I hear ya Paladin, although I don't have to worry about GTA crap...
If you think about it though, there is no where else for a spare... there is only enough room for it deflated anyway... Although personally, I'd rather sacrifice my trunk space for a full sized spare.
1985 Camaro SC - 2.8L, auto.
Mods:
Removed air baffles, mandrel bent cat-back pipes (but stock replacment muffler, Dynomax Turbo and Catco converter are on thier way)
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
