Buying a crank from ebay, help.
Old Dec 3, 2004 | 08:39 PM
paul5.0's Avatar
Car: trans am 1991
ok I have a 350 chevy in the garage. The guy I got it from said it was a roller motor. its a two bolt with these casting #'s 14093638. Im looking at a 383 crank on ebay, but im not sur if it is right. Roller motoers came out in 1987 right? I know this engine uses a one peice rear main seal, but the ebay advertisement stats that the crank "is for a one peice rear main seal 1989-98 roller motors." Mine is a roller but not a 89-98. Whats up with that?? can I use the crank? is the advertisment wrong? What is the difference between the gen I, II, and III 350's and what gen is mine? I dont want to blow 300$ please advise.
Old Dec 3, 2004 | 08:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"14093638...350...87-95...2 or 4...Roller or flat tappet cam one-piece rear seal"
If the crank is as advertised, it should work.
Any particular reason you aren't just getting a complete 383 kit?
Old Dec 3, 2004 | 09:03 PM
five7kid's Avatar
There's no particular reason for the years they listed. The '87 through '92 cranks are the same.
For the "Gen" differences, Gen I had a lot of differences as the years went by. Gen II is LT1 (and LT4). Gen III is the LS engines.
Old Dec 3, 2004 | 09:04 PM
84camz28's Avatar
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
i have the same motor and would like to know too.what 383 kit should i go with?
evilstuie
Feb 28, 2016 03:33 PM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
