HELP FAST: How to bypass heater core!!!!
Old Jun 7, 2001 | 12:25 PM
Zio's Avatar
Zio
Ok guys, my heater core blew, but this is my daily driver and for right now I am going to bypass the heater core. Do i do this by taking the hose from the top passanger side of the radiator and hook it directly to the intake manifold? If not, could you help me out and explain to me how this is done?
thanks for your time
Tom
Old Jun 7, 2001 | 12:29 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
What year is your car? If it's an 87' or later, just leave the temperature control on the cold position. There is vaccum operated valve under the hood that will not allow coolant to circulate. If you want to bypass it, then you will have to connect the two heater lines using whatever hardware you can find that will do the job.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Jun 7, 2001 | 12:32 PM
Zio's Avatar
Zio
TransamGTA350 thanks for the quick response. I appreciate it. It is an 89, but even with the heater controls off and ti on cold i am still getting antifreeze on my passanger floor. I am just going to hook the two together for now until i get time to fix it. Hell it is summer what do i need a heater for.
thanks
Tom
$750 L98
Feb 1, 2025 02:25 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
