What Cam With These Mods (Confused)
Old Jun 6, 2001 | 11:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
89 Formula 350 , TrickFlow 23* heads , Port & Polished Edelbrock Intake , AS&M Runners, Ported Plenum , TES's and Catback , 1.5 RR's I was thinking the Lunati 215* Crane 214* or can or should I go higher? Thanks
Old Jun 7, 2001 | 08:31 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I would try to find something a little more. Try about 220 intake at 113Lsa. What gear and converter you got?
Your going to really want something in the 520 lift range and that will be tough to find with <220.
Old Jun 7, 2001 | 08:57 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Stock converter and 3.27 Posi
Old Jun 7, 2001 | 12:55 PM
Synergy's Avatar
Well I have pretty much the same combo. My cam gets me in the mid 12s so I'm pretty happy. A different cam would probably be better though...
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Old Jun 7, 2001 | 01:02 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
you can probably go with the comp XE262H with no problem. 1.6s down the road would be nice. And really wake it up probably (especially with some 3.42s).
If you have any hope of getting 3.42 and a converter (or maybe 373s), the XE268H would also be real good.
Comps web page is not working. Go here http://www.compcams.com/catalog/056_057.html to see the ones above.
If you can get the roller versions of these cams
http://www.compcams.com/catalog/060_061.html
XR269HR or the XR276HR. With 1.6s on the combination you got it would scream
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
lt1z350
Aug 28, 2015 05:57 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
