maf problem
Old Dec 6, 2004 | 09:43 PM
new442's Avatar
maf problem
My 89 L98 engine shows a 33 code soon after start up. Using the
factory trouble shooting procedure there is no problem found.
replacing the maf with a known good one after erasing the 33 code still results in a 33 code and putting my maf sensor in the doner car does not cause a code. The sensor output wire is continous to the ecm pin. . the dc voltage to the ecm pin stays at 5.0 volts regardless of rpm. Does this point to a problem in the
ecm box or the eeprom?
Old Dec 6, 2004 | 09:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the TPS and the air duct for the MAF sensor? What kind of air filter system are you running?
Old Dec 6, 2004 | 10:19 PM
new442's Avatar
Maf problem
I haven't checked the TPI recently. Using open k&m 3 inch diameter filter. No air leaks after maf sensor.
Old Dec 6, 2004 | 10:21 PM
new442's Avatar
Sorry, I meant the TPS. I will check it this friday or before.
Old Dec 6, 2004 | 10:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The code 33 would be set if there was too much air going into the MAF sensor at start up or soon after.
Old Dec 7, 2004 | 06:15 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
My code 33 was driving me crazy. Long story short, correctly setting the TPS (mine was at 3.5 @ WOT instead of above 4) solved the problem. Haven't set the code in months. Good luck.
Kevin
Old Dec 7, 2004 | 02:14 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Could be your MAF relay. With your car off, remove the ducting to the MAF sensor (but leave the MAF wiring harness connected) and look at the heating element/wire inside the MAF. If it's glowing your relay is bad and this can set a code 33. I had this happen to me, drove me nuts....and a new MAF realy fixed the problem! Good luck.
Old Dec 7, 2004 | 07:38 PM
resqbubba's Avatar
Car: 1989 Firebird T-Top
Check out these posts, it may help you some:
https://www.thirdgen.org/techbb2/sho...hreadid=267568
Old Dec 8, 2004 | 10:16 PM
new442's Avatar
maf problem
Thanks guys for all of your recommendations. It turned out to be the ecm.
chazman
Aug 28, 2018 03:25 PM
GTAman
Sep 21, 2015 09:57 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
