TF 23* CNC porting or no?
Old Jun 5, 2001 | 11:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i know CNC is better but is it worth it. If I decide to go with the non CNC will there be a big differance? Thanks
Old Jun 6, 2001 | 04:18 AM
ede's Avatar
ede
cnc is controled and repeteable. it does the same thing everytime. the program is set up to make the most flow. porting heads by hand is a hit or miss deal. still lot of heads have been ported by hand with good results if the porter knows what he's doing. for a street car i wouldn't pay for cnc work.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
[This message has been edited by ede (edited June 06, 2001).]
Old Jun 6, 2001 | 07:07 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Plus it kicks the chambers from 64cc to 67cc. So the added flow might not outweigh the compression diff without a mill ($$)
Old Jun 6, 2001 | 10:13 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Next ? do I want 1.25 Valve Springs for $875 or 1.47 Sptings for $950?
Old Jun 6, 2001 | 11:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get the bigger springs. That way you'll be ready for any cam you'll ever put in it, and you won't have to get it done later. The larger springs are fine with a smaller cam, but not the other way around.
ICON Motorsports
Old Jun 6, 2001 | 09:21 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
btt
Old Jun 7, 2001 | 04:34 AM
ede's Avatar
ede
as RB said run the bigger springs, you can always run smaller springs in the larger spring pockets but not the other way around. the last set of 1.5 lunati springs i bought cost 130 dollars and the last set of 1.25 lunati springs cost 50 dollars to give you an idea of the cost differance.
ICON Motorsports
1st & 3rd
Old Jun 7, 2001 | 07:56 PM
james_fearn's Avatar
I had the 23* CNC heads with the bigger spring. I like them but when I found out that they were like 66 cc intead of 64 cc I was kinda dissappointed. I needed 60 cc and was going to have them milled but removing that much material on $1100 heads which would void the warranty, I returned them for edelbrock 6085s. The chambers look pretty cool but like all CNC heads that are CNC'd from a casting there were some parts in the chamber which still had the casting flash, although they were small areas.
I wish they had a performance head option that had the CNC chambers but was offered with 60 cc chambers. I would have kept those.
James
1985 Z-28 305 TPI
165 ECM,STB,SFC,GW "wonderbar"
Old Jun 8, 2001 | 07:41 AM
blak92!'s Avatar
CNC of the combustion chambers would not have a significant effect on power. But the 66cc chambers would be excellent for supercharging applications because of the slightly reduced compression. TF 23 heads are excellent quality, the casting is great. My friend purchased the CNC chamber version for use with his procharger. Unfortunately I bought my AFR heads before these heads were released, could have saved.
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
