Why won't it run????
Old Jun 9, 2001 | 12:34 PM
Kyle F's Avatar
We had a fuel pump go out in a 89 TBI after dropping in a new 305 Engine with LT4 cam Vortec heads bla bla bla and so on with a custom chip for it from fast chip. Anyways first off we couldnt get the timing set right. Well that wasn't the problem it ended up being that the fuel pump would not get wenoug fuel to the engine to run right. Ok fine new pump is in and we have plenty of pressure. So now what? We cant get the base timing set because the car is running like **** and it will just up and die.
So here is the smptom it is WAY TOOOO RICH!!!!!!! at idle black smoke is coming out of the exhaust. Not really thick, but its noticeable. SO whats wrong?
I think the MAP sensor may be bad? what else could it be?
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 9, 2001 | 12:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Test the MAP first with a MightyVac or similar, forget which way to watch the voltage swing, but should swing from 5v to about zero, or vice-versa.
The MAP should also hold vacuum when applied.
But I'd be thinking about the big cam (for the 305) and the FadtChip may not be right yet.
Have you tried the stock chip to see if things get better?
Old Jun 9, 2001 | 01:06 PM
Kyle F's Avatar
Stock chip is gone, but we put the old hyperjunk back in and it did basically the same thing.
camaro11j
Sep 19, 2018 08:49 AM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
