Spring Pressure, Rockers?
Old Dec 10, 2004 | 12:44 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I'm going to be using a 214/222 cam with .488/.509 lift at the valve. The crane cam recommended spring is 115lbs closed load and 311lbs open load. Do you guys think this is too much for a stock rocker? I plan on pinning the studs also. Just not sure if I could trust a stock rocker with this setup or if any stamped rocker would be sufficient. Help me out with some input on this, thanks.
Old Dec 10, 2004 | 01:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I wouldn't "trust" a factory rubber rocker in a factory application let alone any forms of aftermarket. If a budget is of concern, Comp Magnum roller tip rockers are about the best out there.
Old Dec 10, 2004 | 03:57 PM
BronYrAur's Avatar
Engine: 305 TBI
Thanks for the input Stekman, I kinda figured I would go for the Magnums, but I have to try to scrounge up some money for them.
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
