82 Z28 Oil Pressure Guage ??'s
Car: 87 IROC-Z, 82 Pace Car
The oil pressure gauge on the 82 Z28 was was working fine while driving. Stopped for a bit, restarted, no oil pressure. Towed the car to get it checked, had 45 psi of oil pressure, but guage read 0. I replaced the sending unit with the 60 psi unit and still had 0 psi at the guage. I drove the car awhile, hit a bump in the road, and the gauge started working again. It's not working now (again), but don't know where to look. I removed the gauge cluster and couldn't really tell if anything could be wrong. It sound like I have a loose connection somewhere, but where? All other gauges are working correctly. Where should I start looking for this? I also found out that the guage is part of the Tach assembly. Thanks for your help.
87 IROC 350 TPI with less than 10k original miles
93 Z28 Pace Car #494 of 645
86 Olds 442 (All Original)
My IROC Website
Northstar Camaro Club of Minnesota
My IROC Website
i'd guess you have a bad ground somewhere. if it were me i'd replace it and the other gauges with a set of auto meter mechanical gauges.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
ambainb
Apr 25, 2016 09:21 PM
